My Cam Saga/Report
So i swapped my PCM with my buddies. Had a perfect warm start, took it for a drive had idle hang. tuner adjsuted for it. Warm start was a no go again
I would finally say that my car is finally at 96%
My car at start up wants AIR, and ONLY AIR.. after that the IAC drops to 50 steps. But at warm start it want 128+ steps, and the it maxed at .64 g/cyl. So it is not the tune. We also did a speed denisity tune as well, that made it worse.
I was also having some bad gas mileage to. 85 miles under normal driving conditions (shifting under 3K RPMs) i was at 1/4 of a tank. Replace my 02s and pretty i got on a full tank about 160. But i was fvckign around a lot with the tune. Lots of starting and stopping....
So all in all i am going to keep the cam... i think if i were to get a 4.10 i would get rid of the bucking.....
any other thoughts???
thanks to all that have helped me out, not going to name any names b/c i know i will forget someone
I just walked in the door from street tuning my car a little bit, got a perfect idle and the rpm's drop perfect now when I pop it in neutral while cruising, it hold a at a little bit over a grand thern as I go under 20MPH the rpms slowly drop down to my idle of 850. Got that down my tweaking the idle air a bit more and cutting the throttle follower down by 85% in the lower MPH cells. It even works fine with the AC on which is a priority when you live in GA. Now i just have to square the WOT fueling away, its way too rich at WOT, like 10:1 on the top end NA. Thats a simple fix though.
my car does the same thing: pop it into nuetral and the idle hangs at 1100 RPMs, then as i get slower it holds rgiht under 1K RPMs.. the scanner is readign 920-970 RPMs. my car will not idle lower, if it does, then idle dips really bad.... i did have the ac on the other day after a car wash, coming to a stop and i had idle hang
have not yet addressed that to the tuner.. But i prolly will not car b/c i never run the ac in the summer time......... WOT i am at 12.9... at crusie i am 15.0... not to bad...
have not yet addressed that to the tuner.. But i prolly will not car b/c i never run the ac in the summer time......... WOT i am at 12.9... at crusie i am 15.0... not to bad...When i installed the engine I set the idle to 950 and left it like that for like a week or 2 but eventually a idle that high drove me nuts. Much better at 850. Im sure you tried but when i dropped the idle speed down i had to increase the IAC park positon table by like 2 counts to get it to hold real good.
yup the idle holding that is a good thing...
i do not mind it at 920-970.. jsut wish it was lower that is all. when i lowered it, i had idle dip or hang.. And in the IAC park table what did you adjsut? what does the table look like i am draing a blank....
Oh and as a sidenote I increased all of my timing tables 4 degrees over stock through the entire thing. I went back in there to check it out to see how much i increased spark, i did a blanket 4 degrees everywhere and it works great so far.
the 110lsa sounds like a pita
trust me you will like the cam on 114.... I am jealous
Post up results when you get it in the 110lsa sounds like a pita
umm yea most of it is below 40 mph.. why? What speed limits do you have lol???
yep my cam has 10* of overlap, not a bitch to pain, but enough to be a PITA!
Brad, i would not gain anything if i were to get an adjustable timing chain and retard it 4* would it? That way it is on a 110 ICL.... no matter what it still has the 10* in it.
