head bolt to stud swap?
Old Apr 4, 2007 | 05:54 PM
quick346's Avatar
Default head bolt to stud swap?
I was wondering being i just got my studs today. from trey04gto and they came out of his 04 gto but my 04gto needs the 03 stlye
I don't have the money now after buying heads and these to get a new set of studs. i need my car done in a week so i can go see my son in michigan.
can i just buy stock bolts for now and just not spray it and swap them one at a time at a later date to studs without pulling the heads to change gaskets.
any help would be great.
thanks
mike
Old Apr 4, 2007 | 06:22 PM
scatillac's Avatar
Default Stud Lengths
The studs/bolts for the '04-up are all the same length. It's the earlier heads that use the longer studs/bolts.
What year is your engine?
Old Apr 4, 2007 | 06:24 PM
cantdrv65's Avatar
Post
What he said.....you bought a set of 04 and up studs since that is what Trey has going by his user name....
Sell them and then do it right with the correct set of studs for your ride....
Old Apr 4, 2007 | 06:30 PM
marv's Avatar
+1...get what you need and do it right...then you won't have to worry about it down the road.
Old Apr 4, 2007 | 07:22 PM
quick346's Avatar
I have no clue guys. my car is a 04gto bought it with 10k miles on it. I just tore it apart. and my bolts are 8 long 2 med and 5 small per side.
Old Apr 4, 2007 | 07:24 PM
quick346's Avatar
also the heads i took off were 241 castings. it was stock when i bought it.
It is the threads are deeper in the block . the studs barely stick out
unless being my car is a 04 it has a 03 ls1. i have no clue
Old Apr 4, 2007 | 07:40 PM
quick346's Avatar
ok i just looked the build date for my car is dec 03 so i dunno
all i know the pic of the studs and bolts for the ls1/ls2 have the same as my stock bolts 8 long 2 med 5 smaller shorter per head
so now what do i rebuy pre 04 or later
Old Apr 4, 2007 | 07:43 PM
brad8266's Avatar
You need the 04 and later studs. Pre 04 blocks take all 10 of the same size bolts, post 04 bolts take 8 long and 2 short.
Old Apr 4, 2007 | 08:14 PM
quick346's Avatar
this is from gm hightech mag
ARP sells this LS1 Pro-Series Head Stud Kit, PN 234-4316 ($372.83 suggested retail). It'll work for all LS1 and LS6 engines built through 2003; GM switched to all-same-depth bolt holes in 2004 so ARP has a separate part number for these later engines. Rated to 190,000 psi, the kit includes 12-point nuts but can also be had with hex-head nuts. There are a total of 10 8mm studs and 20 11mm studs; the stubbier 11mm studs (four in all) will install into the upper front and upper rear 11mm holes on each head surface. As to the 8mm studs, the GM service manual says to install the factory 8mm bolts using thread locking compound, so we'll use some on these too. As a side note, threadlocker is OK to use on all the ARP studs for a more permanent mounting, i.e., if you are taking heads on and off constantly on a race motor and don't want them threading
Old Apr 4, 2007 | 08:18 PM
brad8266's Avatar
^^^ Ok but all my bolts that came out of my 2000 engine were the same size.
mrr23's Avatar
it's the other way around.
Old Apr 4, 2007 | 08:22 PM
brad8266's Avatar
sorry, i guess my dyslexia is kickin in. I swear the bolts that came out of my 2000 were all the same size.
Old Apr 4, 2007 | 08:31 PM
mrr23's Avatar
in my 1999 formula, i used the 134-3609 8 long 2 medium bolts. i'm using the same in a 6.0L motor right now.
don't know why your 2000 had all the same length. did you buy the car new? or used? maybe someone replaced the motor?
edit, saw you edited yours.
Old Apr 4, 2007 | 08:40 PM
brad8266's Avatar
I bought it used but it was stock. Nothing was taken off that motor, i can tell when parts have been pulled off usually.
Old Apr 5, 2007 | 05:28 PM
quick346's Avatar
Even auto zone has 2 part#'s for head bolts for the 04.
So bad on me for not knowing. but hell i did not now. that seems like something ford would do.
put 2 diff engines in the same year car.
anyhow as soon as i hit 50 post they are going to the for sale section for 100 bucks
and in the meantime i am waiting for the big brown truck to bring the right one's
mike
Old Apr 5, 2007 | 06:21 PM
1320 killer's Avatar
yeah you can bolt them in fro now.
Old Apr 5, 2007 | 07:06 PM
quick346's Avatar
Thats what i am thinking. i sprayed the **** out of it before. prob 20 bottles at 150 before i tore it apart with stock heads and bolts.
i will be makeing more power with the heads but i just won't spray it till i get the studs.
i am going insane with out my car running.
is this the norm? do most peaple think non stop all day about how they can get the car running again.
it is all i can think about!!!!
damn i am scareing myself now.
mike
