need help with new head cam choices
Old Apr 4, 2007 | 08:11 PM
jegan1989's Avatar
Default need more power
i have a
LME fully built 408
forged eagle crank
callies compstar rods with arp 2000 bolts
wiesco -8cc pistons
hellfire rings
Federal Mogul bearings
built for the spray
AFR 225cc heads Fully hand ported and polished
the engine is built for n2o it can handle a 400 shot
but na the car will make 490/520 hp/tq but i want a better head cam package than what i have now it is not a big cam at all and i can not remember the spec on it
i am looking to make at least 600/600 hp/tq or more if i can
money really does not matter
i would like to know what size cam
what heads and pistons
were to get these from and what else i might need to run the set
and how much it would cost
thanks joe
Old Apr 5, 2007 | 07:46 AM
STRIPSTAR's Avatar
600/600 is tough to do with an auto trans N/A. More cubes would help and I would look into the larger ET heads like 245-s and raising the compression, sheet metal intake and maybe a solid roller cam setup.
Old Apr 5, 2007 | 07:48 AM
STRIPSTAR's Avatar
I also would ask Mike Kleman @ Rapid >sponsor. He almost stricly builds big cube N/A motors and just did a 6-700 N/A motor for a kid around here in a c5.
Old Apr 5, 2007 | 10:17 AM
jegan1989's Avatar
bump for some more options
Old Apr 6, 2007 | 08:00 PM
jegan1989's Avatar
bump for more help and other options
Old Apr 6, 2007 | 08:19 PM
1997bird's Avatar
I like the reccomendation for the ETP heads as well. What are the specs on your old cam?
Old Apr 7, 2007 | 10:14 AM
PREDATOR-Z's Avatar
12>12.5:1 compression with a custom cam will get you there
