Who is Still using Comp941's
Old Nov 17, 2002 | 02:21 AM
VX SS's Avatar
Default Who is Still using Comp941's
Working on new setup and was considering alternatives. Have had comp 941 in for 60,000 k no probs.Still have spare set seems a waste to change plus my titanium retainers.
Anybody else still willing to use them.
Old Nov 17, 2002 | 07:41 AM
Reckless's Avatar
Super Moderator
Default Re: Who is Still using Comp941's
I got a briefly used set from a friend. He was running them with his T1. I had them installed on my new heads. So far, so good. Cam is 226/226 .591/.591 113LSA.
Old Nov 17, 2002 | 11:38 AM
Damian's Avatar
LSX Mechanic
A buddy of mine runs a TR230 cam with them, no problems. Before that he ran a T1 cam for over 25K miles on Comp 918's, no problems...
Josh
Old Nov 17, 2002 | 11:53 AM
30thta436's Avatar
For what is worth. I talked to Comp cams about the 941's. They said they are only good to a .530 lift. Anything above that and you will be breaking spings. Just letting you know what they told me.
Old Nov 18, 2002 | 12:29 AM
Jake99SS's Avatar
I've had the 941s on my car with a T1 for about 2 years/25,000 miles now. I think the amount of lift you can give them depends on the installed height. I also don't beat on the car until it's fully warmed.
Old Nov 18, 2002 | 04:29 PM
DropTopTerror's Avatar
I'm still running the same set of 941's since I had them installed on my car with 10,000 miles on the odometer. My car now has ~70,000 miles!! Yes, I have ~60,000 miles on my 941's!! I think I hold some record or something. I run my car up to 6000+ rpms at least once a day. It is my daily driver. It currently has 5.3l heads (milled .030, stock valves, three angle valve job), 222/222 .571/.571 114lsa cam (used to have a T1), comp lifters, ti retainers, etc. 2000 trans am ws6 convt.
-E <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 19, 2002 | 05:52 PM
HRT 8's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by VX SS:
<strong>Working on new setup and was considering alternatives. Have had comp 941 in for 60,000 k no probs.Still have spare set seems a waste to change plus my titanium retainers.
Anybody else still willing to use them.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Garry, Peter supplied me with the dual Isky's when I got my cam from him. Have approx 10k on them with no issues. Was revving to 6700 rpm, but now only to 6500.
Old Nov 20, 2002 | 03:58 AM
JackZ28's Avatar
Katech still swears by the 941s. I had them installed with my new cam, with titanium retainers, so hopefully I'll be ok. We'll see.
Old Nov 20, 2002 | 05:33 AM
strife's Avatar
Gary you havent answered your thread <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
Old Nov 23, 2002 | 07:01 PM
RoyO's Avatar
I just installed a TR224/112 cam in my car with 941s and titanium retainers.The car is a daily driver and so far so good.Ive got about 2k on them so far with a bunch of 6400rpm shifts.
Old Nov 24, 2002 | 08:23 AM
JackZ28's Avatar
Dayum, that's brave, but great to know! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 24, 2002 | 09:52 AM
Cliff's Avatar
I have had 941 springs in my motor for less than 5,000 miles. Cam, exhaust 573/595 @ 112 LSA. I have had 2 broken springs. One after hitting the rev limiter (6,700) rpm. Braking the spring and inner coil. Destroying 2 shims and the roller rocker let go putting 33 needle bearing in the motor. (I have only found 22 of them). The second time, I was driving 50 mph and it let go. If It wasn't for good friends who are LS1 techs I would be <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
I don't feel secure driving any distance knowing the springs will let go at anytime without warning. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
<small>[ November 24, 2002, 09:53 AM: Message edited by: Cliff ]</small>
Old Nov 24, 2002 | 01:01 PM
98 Hawk's Avatar
Man, I have about 20,000 miles on mine. Not using alot of lift .525/.532 but I've seen the 6700rmp limiter several times. Shifting alot at 6500rpms. Never a problem. I have some 918's ready to go on but who knows if I even need them.
