question on head studs
Old Nov 20, 2002 | 04:31 PM
minty's Avatar
Default Re: question on head studs
WOW, I think you should read your instructions that came with the studs. That have made some improvements and it seems not all the stud packages are the same. I know that I have seen a set at 80 and 22ft/lb.
Old Nov 20, 2002 | 10:00 PM
10secondZ's Avatar
sweet thanks guys,
Well the stud kit I got did not include instructions for ft.lb specs...i have actually gotten a few things from ARP im the past, for mopar and ford applications that did not come with instructions either...but it's no big deal to me since I have a tech forum to go to and find the proper specs <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> thanks again guys,
carter <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Nov 21, 2002 | 12:18 AM
10secondZ's Avatar
Default question on head studs
hey guys,
well my question is, when the studs are in the block and the heads are on...do i follow the factory sequence for tourqing but instead of using an angle meter guage go in increments to 70 ft. lbs? or do i go by factory specs totally?..like 22 ft. lbs and additional 90 degrees?..thanks in advance <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
carter
Old Nov 21, 2002 | 12:28 AM
Slowhawk's Avatar
LS1Tech Sponsor
Torque them in sequence up to 70 ft/lbs for the mains and 25ft/lb for the top studs <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ November 20, 2002, 12:28 PM: Message edited by: Slowhawk ]</small>
Old Nov 21, 2002 | 12:55 AM
jmX's Avatar
jmX
Most people with the ARP stuff do one pass at 30lbft, one at 50lbft, then a final pass at 70lbft using the proper bolt tightening sequence. You dont use a torque angle meter at all on ARP bolts/studs since they aren't TTY bolts.
Old Nov 22, 2002 | 06:16 PM
minty's Avatar
It's impossible not to get instructions. They are on the back of the box that the studs came in. Check the box again.
Old Nov 22, 2002 | 09:54 PM
10secondZ's Avatar
lol sweet,
I just looked..and yeah i guess I kinda feel like a dumbass.I was expecting a peice of paper inside....thanks!
carter
