What seat pressure?
Old Nov 22, 2002 | 12:04 AM
I follow no 1's Avatar
Default What seat pressure?
What seat pressure are you guys running the 918s at?Does it depend on your lift or just the spring?Also what is the correct install height? Thanks in advance
Old Nov 22, 2002 | 12:17 AM
Tin Indian's Avatar
Default Re: What seat pressure?
Valve seat pressure (closed) is not changed by cam lift.
Spring 'Installed Height' does effects seat pressure.
918 springs are recommended to be installed at the stock GM spec of 1.80" 'Installed Height'.
The 918s when installed at 1.80" will yield a 130 LB seat pressure.
Ron,
Here is the link to the 918 springs >
http://www.compcams.com/information/...6915_26918.pdf
______________________________________________
<small>[ November 22, 2002, 12:28 AM: Message edited by: Kimchee and Rice ]</small>
