Oil Pan Clearance
Old Apr 5, 2007 | 07:05 PM
JASON11WS6's Avatar
Default Oil Pan Clearance
I am currently in the midst of a high boost procharged build up. I recently purchesed a BMR K member and was wondering if that would add any extra clearance for a truck oil pan. I've read that the truck pans are bigger and have a bigger windage tray. I also heard they are just all around better suited for a high hp build. Anyone try it before in an Fbody.
Old Apr 6, 2007 | 06:44 AM
King James's Avatar
You will hit and scrape the pan constantly, even on a stock height car. It hangs down a good bit further then stock. I personally wouldn't run one, again
Old Apr 6, 2007 | 09:26 AM
bczee's Avatar
The Truck pan is about 3" deeper than a F-Body pan. Don't thing it is a good idea unless your going to go and raise your car.
Old Apr 6, 2007 | 11:19 AM
JASON11WS6's Avatar
Thanks guys, sounded like a good way to upgrade the old oiling system. I didn't know it was that much bigger!
