Whos running sbc rods?
The Gen 3 & 4 rods are centered with respect to crank end and pin end. These rods are called "on center" rods.
The piston pin offset is with respect to the major/minor thrust sides of the cylinder. This tends to lessen the wall loading, reducing piston rock (and resulting ring land wear issues and oil consumption) and quieten the piston noise.
Your concerns should center around adequate pin boss clearance with the SBC rods as well as the loading issues caused by using the offset rods.
Mahle makes a damn good piston (both in forged and in hypereutectic) and is OEM on a lot of European Cars and bikes.
