Removing MLS Gasket Layers
Did anyone try raising compression by removing layers of the stock LS1 MLS head gasket?
I've read about Victor Reinz® Victo-Stack® head gasket kit, which features an advanced, modular, multi-layer steel (MLS) design offering the advantage of being able to easily raise an engine’s static compression ratio by lowering the cylinder height or, conversely, to lower the compression ratio by raising the cylinder height. Not sure if it's available for LS1 engines.
Originally Posted by bluecamaroz28
Did anyone try lowering compression by removing layers of the stock LS1 MLS head gasket?
Originally Posted by brad8266
I wouldnt even try that on a regular MLS gasket.
LS1 MLS gasket has three layers.
What is the harm if one removes the two outer layers and leavesthe inner one?
Why is that?
Why is that?
wow. no reason to do that. just mill the heads.
I wouldn't do it, and also it woulds raise your compression, NOT lower it.
