good modifications
Old Nov 25, 2002 | 12:08 AM
LS1 Brent's Avatar
Default good modifications
what are some good, cheap mods. i can do to my 1998 Z28 A4 with out having any problems with anything?
Old Nov 25, 2002 | 09:44 AM
HITMANSS's Avatar
Default Re: good modifications
The easiest mods are a lid, a cutout, and a good set of drag radials. Lots of A4 guys have gotten into the 12's w/ nothing else. The free ram air mod is good, as is the throttle body bypass mod. If you have a Dremel tool, porting the throttle body is good. An ASP underdrive pulley costs around $250, but is worth 8-10 ponies. You can usually pick up a used MAFT for $100 or so, & use it to lean out your fuel mix.
Old Nov 25, 2002 | 01:08 PM
LS1 Brent's Avatar
thanx for the info!
