I need some help here....
Old Nov 29, 2002 | 08:53 AM
2001 Pewter WS6's Avatar
Restricted User
Default I need some help here....
Here is the deal. I have a set of 5.7 heads coming that are milled .030 my push rods are 7.350". What is the maximum lift cam I can run without having P/V clearance issues? I am looking at the TR/224 or the MTI C2. Both are 224/224 but one is .563 lift and the other is .581. Also exacitly what effect does having 0 +2 or +4 advance ground in have? Should I swap out the rods for 7.400" ones. Please advise.
<small>[ November 29, 2002, 08:55 AM: Message edited by: 2001 Pewter WS6 ]</small>
Old Nov 29, 2002 | 08:07 PM
highgmc's Avatar
Default Re: I need some help here....
back when I was first doing mti s2 heads and c2 cam they sent me 7.400 stock length pushrods, that was going on my stock bottom end with LS1 heads milled .030.
Old Nov 30, 2002 | 12:08 AM
99 Black Bird T/A's Avatar
P to V issues tend to occur more because of durations than because of lift. I don't think there would really be much difference in a TR-224 and a C2 as far as P to V goes.
My car has very tight P to V with a 224 XE-R cam that's almost identical to the C2. My car was the exception as most don't have issues with a 224 cam as long as the heads haven't been milled excessively. By degreeing the cam and installing with 2 degrees advance, my car has good P to V clearance. Be sure and check P to V on your set up. Lot's of other people used heads milled as much as mine were with bigger cams and didn't have issues. Lot's of things can effect P to V like: the thickness of the compressed head gasket being a prime factor or if the valves are sunk an extra .010 or whatever. That sort of thing makes it really hard to accurately speculate.
Good Luck
Old Dec 1, 2002 | 07:40 PM
Restricted User
Thanks for the info...
