photos gm 2002 cnc ported ls6 heads
Old 10-05-2002, 10:21 AM
07BlueDevilZ06's Avatar
Default Re: photos gm 2002 cnc ported ls6 heads
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by z28kid98:
<strong>i think the '01 and '02 difference is in the valves. the '02 has the sodium filled valves that were mentioned above. plus the springs may be different since the cam was changed from '01 to '02. not sure on that. can you get bare CNC ported LS6 heads? cause then you could throw on the springs that will work with a larger cam. almost the same
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">the springs are better on the 02'zo6 and if you dont make the valves bigger it would be worthless to run a bigger then 525-560 cam thats what these heads are designed to run max flow is at 525.you always should match your cam to your heads not heads to your cam that way you can make best power
george
Old 12-12-2002, 01:01 PM
Zeta's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2002nhraformula:
<strong>
george
http://www.cardomain.com/member_page...=238515&page=2</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Please see the above or:
http://images.cardomain.com/installs...15_13_full.jpg
Note the hand written info on the tag, 1.150 and .560 lift.
Is the .560 lift the max reccomended?
0.560 * 1.7 = 0.952
George what is the specs on your cam?
Old 12-13-2002, 02:45 PM
my cam is 525 lift
