dropped the oil pump bolt: need advice
what are my options?
any ideas would be a big help at this point
mike
I can't drop the pan with it in the car.
thanks
hopefully a oil change or 2 she will come out the drain hole.
thanks
Anyway. Just remove all the oil pan bolts and the 2 bottom trans bolts(auto, dont know about m6) and then remove the bolts from the motor mounts wile supporting the front pulley with a jack... I would also put a jack on the trans pan.. Then you can lift the motor a little to get it out. Doesnt take a lot. I have not done this but have read about it.
I would fish a litttle more but if you cant get it i would go this way. Maybe look up some more info on how to do it. I read supporting the motor w/ the front pully will not hurt it.
I unbolted the engine mounts and jacked it up as far as i could then dropped the pan as far as it would go. I had it once about 5 hrs ago. but then lost it.
so in the end not takeing 2 minutes to wire the bolt cost me 2 days and 1 day off work
now it was worth takeing the day off work.
and also i found the pick up tube has NO screen.
by a bolt, lol.Id get a new pickup tube that has a screen if I were you.
