Hot cam specs. Help newbie cam guy decipher
Old Dec 1, 2002 | 04:29 PM
LS1swap's Avatar
Default Hot cam specs. Help newbie cam guy decipher
I have the hot cam and it cam with a spec sheet. I know very little about cams explain to me what they represent
Intake Exhaust
Lobe lift: .308 .308
Gross valve lift .525 .525
Lobe centerline 109 deg. 115 deg.
Duration @.006" 271 280
Duration @.050 218 227
Rocker arms ratio 1.7 1.7
Valve lash zero zero
Lobe separation 112
Thanks!
fixed <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ December 01, 2002, 04:51 PM: Message edited by: LS1swap ]</small>
Old Dec 1, 2002 | 04:34 PM
BYBYC5's Avatar
*Bad Trader*
Default Re: Hot cam specs. Help newbie cam guy decipher
<img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
think the .050 duration should be 218/227.525.525 112
Old Dec 2, 2002 | 07:27 PM
wrencher's Avatar
wrencher
Go to crane or comp. cams web site their write ups will help you out. That's alot of info to try & explain.
