Solid Roller ?'s
Old Dec 3, 2002 | 06:16 AM
ShiznityZ28's Avatar
Default Solid Roller ?'s
I bent a valve over reving so i had to pull a head. so i was thinking why not pull both and go sollid roller? If you guys could give me a list of parts needed. and estimated cost that would ROCK! I plan on going to double springs to. also what would be a good sollid roller cam? Drivability is not a factor. only 1/4 mile ET's
Thanks
Old Dec 3, 2002 | 07:19 AM
Camaroholic's Avatar
Default Re: Solid Roller ?'s
You'll need to contact sponsors to get exact pricing (I'd suggest Thunder Racing and Futral Motorsports, links to the right -> ). When I was looking a while back, it was looking to be ~$5500(give or take a few hundred) for GTP S2 heads machined for double springs & shaft rockers, cam, the shaft rockers, head studs, spark plug wire relocation kit, lifters, gasket kit, and maybe the piston notching tool (not necessary, but if you're gonna go, go BIG <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ). If you just machine your heads, you can probably knock off ~3k of that.
I ended up not doing the heads/cam, but it was interesting nonetheless.
Good luck,
Andrew
Old Dec 3, 2002 | 09:22 AM
GTP LS1's Avatar
Are you still running the stock shortblock? If so, it may not last long spinning to 7,500 rpm.
Old Dec 3, 2002 | 10:50 AM
Yes i have the stock bottom end and i plan on staying at 7000 or so for now(until forged 382 all bore) I have heads and a flycutting tool and i am gona mill them for double springs (even if i stay hydrolic) but ohter than that i guess i need. lifters, rockers,pushrods? anything else? thunder has these? thanks for the help guys.
if i don't go sollid now i am gona fly cut and go big cam. any thoughts?
thanks
Old Dec 3, 2002 | 11:37 AM
GTS SS's Avatar
I have my first solid roller cam for sale, it might be what your looking for.
236/241 .680/.680 112 LS, using 1.7 ratio T&D rockers.
I shifted at 7000 rpm with this cam.
Dyno #'s were 460 rwhp/418 rwtq with my old FMS Stage 2 LS1 Heads, 4.56 gears.
Best ET with this setup was 10.94 @ 124.56 mph 1.54 60', 3480 lbs raceweight.
Gordon
Old Dec 3, 2002 | 11:53 AM
ls1290's Avatar
Dumb Ass Vette Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GTS SS:
<strong>I have my first solid roller cam for sale, it might be what your looking for.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Gordon, what type of pistons do you have? Are they cut with valve relief?
Old Dec 3, 2002 | 01:08 PM
JS's Avatar
JS
U over-revved an automatic?
I did that once too w/my BB Nova,I froze on the one/two shift.
Did ya get a run w/the T-BRAKE at all?
Thats sucks man....
I'd sty hyd. if it was me,TR 230-224 and the brake should work real well.U can just upgrade to the REV dual spring kit and be done with it...
Good luck...
JS
<small>[ December 03, 2002, 02:07 PM: Message edited by: JS ]</small>
Old Dec 4, 2002 | 12:02 AM
GTS SS's Avatar
For that setup I had Wiseco pistons and they had valve reliefs.
Old Dec 4, 2002 | 07:25 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JS:
<strong>U over-revved an automatic?
Thats sucks man....
Good luck...
JS</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">not real shure when but i remeber the tires breaking loose at the top of 1 and taping it once before i grabed 2nd. no no t-brAke yet cause i broke the 10 bolt before i had the chance.
I think i am gona fly cut the pistons put a nice hyd. cam (234 234 591 591 109or110) on the x-er lobe. Should be fun. but i am gona put it back togeather now w/flycuts and keep the 224 224 until next season. cause i want to know what this cam can do first.
I think i will start stock piling the stuff for sollid roller
thanks for all the help guys.
Old Dec 4, 2002 | 10:16 AM
JS's Avatar
JS
If your pulling the car apart put the big hyd. in now and be done with it.
Good luck and have a happy holiday...
JS
<small>[ December 04, 2002, 10:19 AM: Message edited by: JS ]</small>
Old Dec 4, 2002 | 05:25 PM
GrannySShifting's Avatar
<strong>If your pulling the car apart put the big hyd. in now and be done with it.
JS</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thanks man you to.
