425 hp with 01 LS6 cam
Old Dec 4, 2002 | 08:16 AM
Larry's Avatar
Default 425 hp with 01 LS6 cam
This is what the calculations says. We do believe this don't we?
<img src="http://www.mustangmods.com/publish/8850//425hp" alt=" - " />
Old Dec 4, 2002 | 08:18 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default Re: 425 hp with 01 LS6 cam
Is this the time from a 2001 Z06 you are referring to? Also, your weight is a bit on the high side if it is a Z06.
Old Dec 4, 2002 | 09:05 AM
Larry's Avatar
No Z06! I have a 98 Camaro with the 01 LS6 cam and LS6 intake. Here'a my mods: http://xs-fx.com/raughammer/larrysample.htm
Old Dec 4, 2002 | 02:57 PM
2000SILVERTA's Avatar
It says you used more HP than you have? Cool.
Old Dec 4, 2002 | 03:05 PM
DONAIMIAN's Avatar
Hmmmm thoes numbers are a lil too high, well I dunno hmmm with your ET it looks more like around 400 but I doubt 425
Old Dec 4, 2002 | 04:35 PM
Ian's Avatar
Ian
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2000SILVERTA:
<strong>It says you used more HP than you have? Cool.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LMAO! I think this calculator leaves way to many variables out of the equation to be very accurate.
Old Dec 5, 2002 | 12:28 AM
J-Rod's Avatar
I have found many of those programs "oversimplify" the HP calculations. If you run X mph then it takes Y HP.
Depending on whose calculator you use, I have seen the result vary greatly when using the same data.
<small>[ December 04, 2002, 12:31 PM: Message edited by: J-Rod ]</small>
Old Dec 5, 2002 | 07:34 AM
Larry's Avatar
With my converter lock up switch on I dynoed 359 hp before I installed this LS6 intake. 336 with converter unlocked. I think the calculations are a little bit high for sure.
<small>[ December 05, 2002, 07:35 AM: Message edited by: Larry ]</small>
