Holy FREAKING POPCORN BATMAN!!!
Old Dec 4, 2002 | 11:06 PM
The Dragon's Avatar
Default Holy FREAKING POPCORN BATMAN!!!
I didn't realize my A/F would be THAT messed up!!!
Just picked up my baby after installation of S2 Heads, TR 224 cam 112 LSA; other mods in my sig.
JESUS <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Sounded like Orville Red 'n' Bacher in my engine when I layed into the throttle a bit <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
With my MAFT set at 15% rich base 0 WOT, my O2's averaged .651 and +2.15 LTerms <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Applied the throttle (not even near WOT) and popcorn at the movies <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" /> The mech told me with my intake wide open: TB, MAF, Lid, etc. I needed a LOT more fuel (this I already knew . . . just didn't know it would have this SERIOUS of an effect).
I multiplied my PE rpm value by 120% and kept the MAFT at 15%; O2's .501 and LTerms at +1.65 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> no popcorn this time <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
My timing at idle was ~14* . . . that sucks.
Didn't do a WOT tap yet, I'll wait 'til Friday night.
The above readings are confusing the crap outta me <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Any help guys?
Old Dec 4, 2002 | 11:34 PM
Dope's Avatar
Default Re: Holy FREAKING POPCORN BATMAN!!!
You might want to read up on tuning a bit, I have no idea why you're checking your O2s at cruise (only time you care about is at WOT), or why you're checking your timing at idle (???). You can get a good idea about your ltrims when you are in certain fuel cells (don't remember off the top of my head), but it only involves checking when you're on the gas, not deaccel or idle or wot. You'll get lots of different values, so you have to average them out. Negative a couple, on the ltrims, is about where you want it. Depending on your year you'll want to be seeing mid or high 20s for timing at WOT (at high rpm), and high .800s/low .900s on the O2s at WOT as well.
This is pretty rudimentry, like I said, you might want to read up on tuning a bit before you start changing all this stuff with your MAFT and LS1edit, when you could be causing serious engine damage.
Dope
Old Dec 4, 2002 | 11:51 PM
The Dragon's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dope:
<strong>
Dope</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Exactly the reason for my query dope.
Pinging in my engine is DEFINITELY a cause for concern.
I do not know how to monitor separate fuel cells (I think I was told #19 . . . not sure about that).
I do know that I won't learn if I don't ask.
Thanks for your help though <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
One other thing: the PE thing . . . I got from a variety of people on this, and other, forums <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'm not about to keep it "as is" when my engine is definitely in need of fuel <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Dec 4, 2002 | 11:57 PM
The Dragon's Avatar
<strong>. . . Negative a couple, on the ltrims . . . 20s for timing at WOT (at high rpm), and high .800s/low .900s on the O2s at WOT as well.
Dope</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am well aware of the fact that I want my Lterms to average -1 to -3.
I also know about the timing <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I referenced my timing issue because before install, my timing was ~19 at idle.
I also know that O2's should average ~880-890 at WOT <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'm merely trying to give as much information as possible in order to give a better platform from which to form a diagnosis from more educated members <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I have no idea what they would need to look at in order to offer assistance.
And, as I mentioned in the original post, I could not go WOT without MAJOR pinging and loss of hp.
Pinging go bye-bye after PE adjustment <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 4, 2002 | 11:58 PM
DONAIMIAN's Avatar
Thats too confusing thats why I leave the tuning to the pros. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Dec 4, 2002 | 11:59 PM
jmX's Avatar
jmX
Put the tuning/maf back to stock, ditch the MAF translator, and reset the PCM.
What you are describing is *NOT* normal after a heads/cam install, something is wrong. Don't pile on more crap with hacking the tuning just yet, get the car running better first (unless you went with some super high C/R and are using bad gas, which then I guess tuning would be nessisary).
I have been in tons of heads/cam ls1's with stock tuning and not once have I ever expereicened what you are talking about.
Timing at idle? Who cares? O2's at cruise? Um...yeah..they average around 500 because they constantly flip back and forth!#@ <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Before you really mess something up, undo all your A/f hacks and start fresh, or at least, thats what I'd do.
Old Dec 5, 2002 | 12:01 AM
The Dragon's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong>Thats too confusing thats why I leave the tuning to the pros. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have access to dyno-tuning but unfortunately the shop isn't open on the weekends.
They have a wideband O2 and experienced techs but I won't be able to travel to their shop until Monday.
So, between now and Monday, any temporary fixes (or maybe even help on dialing it in before then <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ) would be welcome <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 5, 2002 | 12:05 AM
The Dragon's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jmX:
<strong>Put the tuning/maf back to stock, ditch the MAF translator, and reset the PCM.
Before you really mess something up, undo all your A/f hacks and start fresh, or at least, thats what I'd do.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Before the H/C, I had to adjust my MAF with my bolt-on set-up because I was running lean on the stock tune.
I'd imagine that opening it up further with Stage 2 ported Heads and a larger cam would only augment the lean condition.
I'm not arguing the point, merely attempting to understand the logic <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
If air-flow is increased, wouldn't fuel need to be added?
Old Dec 5, 2002 | 12:09 AM
jmX's Avatar
jmX
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by The Dragon:
<strong>If air-flow is increased, wouldn't fuel need to be added?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats what that little round thing called a MAF is supposed to take care of <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> Put a stock maf on, reset the programming, put some good gas in, and go from there.
Old Dec 5, 2002 | 12:28 AM
The Dragon's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by The Dragon:
<strong>If air-flow is increased, wouldn't fuel need to be added?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats what that little round thing called a MAF is supposed to take care of <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> Put a stock maf on, reset the programming, put some good gas in, and go from there.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So my ported MAF ends are screwin' me up?
If that's the case, I'll throw the stock ends back on tomorrow <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> (it is de-screened, will this have an adverse affect when I reset?)
I always run 93 octane at the same Chevron station.
Are you suggesting I run a higher octane?
Thank you for the information BTW. I was sweatin' when I heard detonation <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
<small>[ December 05, 2002, 12:32 AM: Message edited by: The Dragon ]</small>
Old Dec 5, 2002 | 12:31 AM
J'sRamAir's Avatar
I don't meant to hijack The Dragon's post, but I have a question while we're on this subject. If you reset your computer, would it throw things out of whack if you did so with the MAFT set to say, 5% rich? What I'm asking is, when I reset my computer should I unplug the MAFT? I reset my computer a few days ago and forgot I had my MAFT on there set to 5% rich.
Old Dec 5, 2002 | 09:16 AM
Colonel's Avatar
No need to unplug the MAFT when you reset the PCM.
Yes, aftermarket MAF end will lean your mixture just like porting the MAF will. If after going back to the stock MAF you still have major problems I think your problems are more than a simple air/fuel tune.
Moving to Computer Diagnostics and Tuning... <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
