Cam questions about degrees +/- advanced/retarded
Old 12-10-2002, 05:28 AM
Back in the staging lane
Beeler422's Avatar
Default Re: Cam questions about degrees +/- advanced/retarded
Yeah that's what I meant, on my cam, I am getting 0 degrees on it so that I can adjust it however I want. So I will install it dot-to-dot and then use the cam card. Right?
Old 12-10-2002, 05:42 AM
Tin Indian's Avatar
If you want [no] retard or advance ground into the cam, make sure the LSA and the IC in your cam are both the same. This info can be varified on your cam card that is supplied with the cam.
Now, if you want to install it lets say 2 degrees advanced, just buy an adjustable timing set and follow the instructions that will get you 2 degrees advanced.
Again, a degree wheel (if used properly) will verify the cam card info, but probably is not real necessary.
I think you may just be getting to "wrapped around the axle" on this whole advance/retard deal.
Hey, do yourself a favor (and less headaches) and just buy a Comp Cams with the desired specs you want. It will more than likely have 4 degrees advance ground in it from the factory. Stick it in dot to dot and enjoy. That 4 degrees advance will give you real good throttle response, good low rpm torque, with very little loss of power in the 6,000+ rpm range. Comp Cams puts the advance in there because its a good compromise for your daily driver. Don't loose alot of sleep over all this.... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Ron,
Old 12-10-2002, 10:18 PM
99 Black Bird T/A's Avatar
Received 1,444 Likes on 1,002 Posts
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Kimchee and Rice:
So, in the case of "Put it in dot to dot, and your hot to trot" .... Well, I guess today, that would hold true as long as your happy with the amount of advance/retard the manufacturer ground into it.
Ron, <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Bottom line; If you didn't use THIS, a dial indicator and a piston stop, you didn't "Degree In" your cam!
[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My 224 XE-R had to be degreed in due to P to V issues with my heads. Based on all of the rules of thumb this shouldn't have happened but it did.
Old 12-11-2002, 03:59 AM
Plan B's Avatar
This all sounds like a guessing game. All you need is an engine dyno and one of these vernier timing sets. Only then can you be certain that you have dialled your cam right, for the best most usable power.
<img src="http://www.purefect.com.au/planb/Vernier_Timing_Set2.jpg" alt=" - " />
<img src="http://www.purefect.com.au/planb/Vernier%20Timing%20Set1.jpg" alt=" - " />
Old 12-11-2002, 05:56 AM
VAP
VAP's Avatar
Glad to see you finally got it Pete - Gotta say though mine does look better, but then again i'm sure you didn't pay as much as what i did... <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Advancing makes more power down low and retarding makes more up top..
BS - Getting the cam in the exact right spot makes more power in some places without sacrifice to power in other parts of the usuable HP range.
Like Plan B said all you need is a adjustable vernier set.
AND a dyno good enough to see the REAL small changes to the power & torque..
By the way I've got mine setup so as I can change the cam timing within 6 minutes on a fully assembled engine on the engine dyno, without so much as a water or oil leak <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old 12-11-2002, 07:12 AM
Plan B's Avatar
Thanks Theo,
I've also modded a cover and pump to do exactly what your saying. 6 minutes?? Thats faster than my 1/4 mile time. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
This week.... 244/244 with 106 lsa with in a 346ci. ICL will be where ever we want. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 12-14-2002, 08:59 PM
VAP
VAP's Avatar
I'm really interested in how that cam performs. - I mean REAL interested. let me now <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old 12-15-2002, 06:50 AM
LS1derfull's Avatar
Plan B this cam only works well with custom intake correct? What are the other mods going along with this cam? TIA
Old 12-17-2002, 05:37 AM
Plan B's Avatar
LS1derfull,
It's just headwork at the moment with a stronger short motor. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Quick Reply: Cam questions about degrees +/- advanced/retarded
