gm head gasket kit question?
Old Apr 11, 2007 | 11:12 AM
PREDATOR-Z's Avatar
Originally Posted by Daredevil_TA
does cometic make a heads and cam swap gasket kit? if not then what other gaskets do i need besides the ones for the heads? thanx again predator
Run your setup by me so I can see what is good to choose.
Cam, heads, etc...
Old Apr 11, 2007 | 12:44 PM
PAGregSS's Avatar
ByUnspeed has the same kit for $125 with free shipping.
Old Apr 11, 2007 | 01:39 PM
Daredevil_TA's Avatar
okay this is everything im gonna be installing: LPE GT2-3, Patriot Stg. 1 CNC'd LS6 heads 3.905 bore, Harland Sharp 1.7 RR, Thunder Racing 7.425 chromoly hardened pushrods, ported LS6 intake, Pacesetter LT's, TSP true duals dumped.
Old Apr 12, 2007 | 02:37 PM
bump, waiting for an answer
Old Apr 13, 2007 | 07:11 AM
PAGregSS's Avatar
The cometics really require a nice smooth deck on both the block and the heads to seal well. The MLS gaskets are bit more forgiving. It sounds like they are going to be your best choice.
Old Apr 13, 2007 | 08:34 AM
mushroom281's Avatar
correct me if i'm wrong but shouldn't you be using 7.4 pushrods?
Old Apr 13, 2007 | 12:06 PM
i was told to go with that length to quiet down the valvetrain
