Will motor be ok?
Old Apr 10, 2007 | 07:23 AM
blackfbird's Avatar
Default Will motor be ok?
I am about to install a lingenfilter gt2-3 cam in my car. And needed to know if my shortblock will be ok with 100k miles on the car currently? Is there anything I should worry about?
Old Apr 10, 2007 | 07:25 AM
brad8266's Avatar
Your shortblock will be fine. Just be sure to upgrade your valvetrain. New valvesprings, retainers, pushrods.
Old Apr 10, 2007 | 09:18 AM
bczee's Avatar
What kind of oil pressure do you current read ?
Be carefull that you don't nick the cam bearing as you install it and put a new oil pump on (LS6, Melling and ported if you want).
Old Apr 11, 2007 | 05:44 AM
blackfbird's Avatar
On cold starts my oil pressuer reads 65psi once the car is warm it reads alot over 40 psi.
Old Apr 11, 2007 | 05:59 AM
Danger731's Avatar
As long as you are a tad over 40 at cruise it's working fine.
