Pagin 770 Boy, Cam Question
i.e. Cam manufacturer and grind number or if you don't have that what lobes (comp xe or xe-r).
What lift?
Have you run it at the track and how did you do?
Can you post a dyno sheet and if not can you describe your power band with it (is it hard to start off with, does it have alot of midgrange, etc.)? I believe you said you made 394 to the rear wheels correct. What kind of torque? So many questions but your reply will be greatly appreciated.
BTW, if you are interested in this cam, I have it in my garage for sale.
