cam install question?
Old Dec 9, 2002 | 06:23 AM
2002snortbird's Avatar
Default cam install question?
I want to put a new double row timing chain on when I change my cam. My questions are will the double fit under the stock cover and how do I make sure the cam is timed with the crank; because marking the old one doesn't help(not using it)?
Old Dec 9, 2002 | 09:53 AM
jmX's Avatar
jmX
Default Re: cam install question?
You line up the dots. Nobody marks their old one anyways since they are marked with dots from the factory.
