Cam Advise
Old Dec 10, 2002 | 01:01 PM
SLPSS339's Avatar
Default Cam Advise
I have the 335/HP 02'SS with the LM, 3.42, Whisper lid, and descreened MAF. Called up LS1 Speed and they recomended the following:
Up to 400RWHP is obtainable with this fast ramp cam with bolt ons, STOCK heads, and dynotuning in an M6 car Lift: .581/.581 Dur@.050: 224/224 LSA: 112 114
What do you guys think about this cam or what cam do you recomend? I'm a daily driver, but looking for some lopeing action with power!!!
THNAKS!!!
Old Dec 10, 2002 | 01:04 PM
SLPSS339's Avatar
Default Re: Cam Advise
Oh, I forgot i'm running stock heads, well everything stock.
Thanks,
Old Dec 10, 2002 | 01:10 PM
DailyAluminumBlock's Avatar
I know a guy over on Eastern Fbody that has that cam and stock heads and has hit 399.something rwhp with stock heads. I say go for it.
Old Dec 10, 2002 | 02:53 PM
Loudmouth LS1's Avatar
Would this cam handle spray? Cause if so I may go with this one.
Old Dec 10, 2002 | 03:33 PM
LOnSLO's Avatar
Spray would prefer the 114 LSA in that cam.
Old Dec 10, 2002 | 03:52 PM
So would that cam still put down 400 rwhp with bolt ons and stock heads if it was 224/224 .581 114? Also, how would the idle be, I like the choppy idles, would it be lumpy?
Old Dec 10, 2002 | 04:01 PM
Berniempb's Avatar
Can this cam work with the stock manifolds?
Old Dec 10, 2002 | 04:12 PM
Unless you're going to spray more then 150 shot don't worry about the 112 vs 114lsa. I don't really think you need to take nitrous into consideration for cam choice until you spray more then a 150.
The cam will probably work with out headers but really will come alive once you add headers.
Old Dec 10, 2002 | 04:18 PM
Lesrace82's Avatar
A guy I know is running a cam with those specs that came out of Speed Inc. It cams pretty hard, sounds good, I was thinking of going with the same cam. He is on a 112 lsa.
Bill
