would u please discuss this cam with me
Old Dec 9, 2002 | 03:47 PM
Argon Z's Avatar
Default would u please discuss this cam with me
im looking at installing the ASA cam into my 98 camaro which has heads and most bolt-ons.
i believe the specs are 223/236 at .525 110lsa
would this be drivable on the street?
any tips or info will be useful
thanks
Old Dec 9, 2002 | 04:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: would u please discuss this cam with me
Might surge a bit down low and I would think you'd have to flycut your pistons?
Old Dec 9, 2002 | 06:43 PM
Argon Z's Avatar
any one else please
Old Dec 9, 2002 | 06:52 PM
strokedls1's Avatar
You don't say weather it is an a4 or m6, but I would vote against this on stock displacement. The idle would surge like crazy with a 110 and 236 degree of exhaust. Why not get a 230/227 on a 112 lsa if you want to go big with the cam.
Old Dec 9, 2002 | 06:55 PM
Jelly's Avatar
The ASA cam is very drivable if you have a 6 speed. Also you will not need to cut your pistons at all. I am 100% positive. It a good cam if you do not have any head porting ( stock heads)
Chris
Old Dec 9, 2002 | 06:58 PM
Argon Z's Avatar
is it a good cam with ported heads i have stage 2
cnc
Old Dec 9, 2002 | 07:00 PM
Argon Z's Avatar
it is a t-56 and if anyone has any recomendations on a good cam i would appreciate it, however i was recomended to use the asa cam
Old Dec 9, 2002 | 07:01 PM
Argon Z's Avatar
cnc
Old Dec 10, 2002 | 05:38 PM
1CAMWNDR's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Argon Z:
<strong>is it a good cam with ported heads i have stage 2
cnc</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Probably not...I would think your Stage II heads will flow well past .525" lift. You will need a cam that better matches your cylinder head's flow capabilities.
