99 SS knocking and won't stop after warm-up
I have a 1999 SS and I have the infamous piston slap. Usally stops after 2 minutes of letting the car idle. Now the inital knock is a little louder and it quiets down after the 2 minutes of idiling but it doesn't go away like it always did.
I have smooth maf ends installed and a maf translator. I had to turn up the base on the maft to "1" because I was running lean but I didn't have any sort of problem until a hour ago.
What's going on, is this normal, does the sound get worse with time?
My car used to knock only when cold now it knocks even when hot.Dam GM rep still says its normal >To me it sounds like a wrist pin> I guess ill spray it till it goes clank clank.GM sucks *** about LS1 moise.
