Can anyone help me out with my compression ratio?
Old Dec 13, 2002 | 06:28 AM
StevieZ's Avatar
Default Can anyone help me out with my compression ratio?
My heads have been milled .025 . I will be running the Lunati 382 rotating ***. with pistons that are -8cc. The Lunati kit is supposed to give a CR of about 10.7 to 1 with stock heads. How can I figure out what my CR will be with my heads milled .025?
Old Dec 13, 2002 | 07:36 AM
HITMANSS's Avatar
Default Re: Can anyone help me out with my compression ratio?
A .025 mill should raise your compression ration about 4 tenths of a point. If you want to know exactly, have your combustion chambers CC'd.
This is going to be true whether you have a stroker motor or a stock displacement motor. Milling the head raises the compression ratio because the combustion chambers are smaller.
Old Dec 13, 2002 | 08:57 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I would guestime your compression to be about 10.4:1 based on the following assumptions:
3.9" bore
4.0" stroke
0.054" gasket
67.3 LS1 chambers
milling 0.025" drops 3cc in chamber volume
Old Dec 13, 2002 | 09:59 AM
StevieZ's Avatar
That doesn't make sense. If the CR is 10.7-1 with the Lunati kit and stock cc chambers, then it would be higher with heads milled .025.
Old Dec 13, 2002 | 08:37 PM
wolfman jack's Avatar
did you have your heads flat or angle milled?
Old Dec 13, 2002 | 08:41 PM
StevieZ's Avatar
Flat
Old Dec 13, 2002 | 09:50 PM
if the 3.9 bore & 4.0 stroke & .054gasket is corect then you should have a 11.21:1 ratio
