Help with Pushrod replacement!
Old Dec 13, 2002 | 08:19 AM
JoSeY's Avatar
Default Help with Pushrod replacement!
Could someone give me some tips on this? I've got all the basics...but are there any tricks to doing this once you've pulled the valve covers..getting those off are a snap...
If anyone know's of some writeups or something I'd really appreciate it.
Thanks
Old Dec 13, 2002 | 08:27 AM
Beeler422's Avatar
Back in the staging lane
Default Re: Help with Pushrod replacement!
Getting the valve covers off is the hardest part. After that, just remove the rockers (10mm bolt) and pull the pushrods out. When you replace them, torque the rockers to 24 lbs-ft (I think!) That's it.
Old Dec 13, 2002 | 08:42 AM
LOnSLO's Avatar
Just FYI, it's an 8mm bolt on the rockers. Retighten to 20 ft-lbs for first pass, then turn the engine over a few times, and retighten to 22 ft-lbs. Easy as pie <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 13, 2002 | 08:57 AM
JoSeY's Avatar
THANKS!! I appreciate it...
Old Dec 13, 2002 | 09:27 AM
J'sRamAir's Avatar
Here's a writeup:
http://www.ls1info.com/article.php?sid=97
Old Dec 13, 2002 | 09:43 AM
JoSeY's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by J'sRamAir:
<strong>Here's a writeup:
http://www.ls1info.com/article.php?sid=97</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Damn...that whole site is sweet! Thanks
Old Dec 14, 2002 | 12:35 AM
rom3's Avatar
If you can find one, do yourself a favor and purchase a "6 point" 8mm socket for a 3/8" ratchet. Took me a while to locate one as it is not very common. Those rocker arm bolts are tiny yet on there very tight. When I tried to loosen them with a 1/4" drive ratchet and 12 point socket, they would not loosen and the socket kept slipping off of the bolt. Eventually would have rounded it off.
Old Dec 16, 2002 | 12:57 AM
bomax's Avatar
That article can also be found at:
http://www.ls1camaro.net/sections.ph...ticle&artid=66
Which seems to be a better site...
