Thoughts on ASA or GM HOT CAM
Old May 28, 2007 | 10:08 AM
  #161
GR33N GoblinM6's Avatar
was at the dyno on saturday... but my friend was tuning a GT2 Evo and it took most of the day.. and i couldnt stick around for 9 hours that they were tuning... im going to call him up today and see whats going on.. being a holiday i think he might have plans.. but i'll see what i can make him do since i got jacked on saturday..
Old May 28, 2007 | 10:43 AM
  #162
ok im going down today.. i'll report back this afternoon
Old May 28, 2007 | 05:27 PM
  #163
ok..
372.6rwhp SAE corrected
378rwtq
the barometer was 29.2 (correction)
im happy.. this is on a street tune (tuned without a wideband) and runs a tad rich.. this is awesome.. im well pleased.. and my tuner was pretty much right on the money with his guess..
peak HP was @ 5888rpm and peak torque is at 5225
Old May 28, 2007 | 05:31 PM
  #164
35thUCF's Avatar
nice #'s, I wish I had a T56
Old May 28, 2007 | 05:38 PM
  #165
kevins2000LS1's Avatar
Good numbers im geting true duals put on friday im hoping to pick up a few HP with my ASA. But 375 is good for so little of a cam. So whats that barometer mean??? Im new to that.
Old May 28, 2007 | 06:02 PM
  #166
the Barometric pressure of the atomsphere..
low pressure days results in lower hp #'s..not by much, but typically 10-15 if really low, like say 27 baro
on high pressure days we usually see better hp results.. i help my friend run his dyno shop at times, so he fills me in on the little details.
Old May 28, 2007 | 06:08 PM
  #167
WS6WRX's Avatar
Nice #'s, almost the exact same I got w/ a Hotcam, LT's, Corsa and Diablo tune.
Old May 28, 2007 | 09:17 PM
  #168
Wezie F Baby's Avatar
Originally Posted by GR33N GoblinM6
ok..
378rwtq
Very nice numbers.
I know you probably stated it before, but what supporting mods do you have. I've been looking at this thread for awhile and thinking of going w/ your setup.
Old May 29, 2007 | 05:13 AM
  #169
yes.. i have an LS6 intake..
here are my mods
BBK 80mm TB (came on the car)
Granitelli lid, paper air filter
Granitelli MAF descreened (came on the car)
LS6 intake
241 heads milled .028 (calculated compression of 10.7.1)
GM ASA Cam 226/236 .525 .525
LS2 Timing chain
LS6 oil pump
03+ LS6 springs
GM MLS Head gaskets (.060 thickness)
Pacesetter Long tubes ceramic coated
Pacesetter ORY
Texas-Speed Rumbler catback (single 3" Dynomax Bullet in the Y)
other mods are:
SPEC 3+ clutch
New GM stock flywheel
updated hydrolics (with Drill mod)
Pro 5.0 shifter
rebuilt T56 from T56 rebuilds, 1B package
GM 4.11 gears
C5 front brake conversion
Eibach pro kit
Hotchkis APHB
BMR relocation brackets
Hotchkis trailing arms
Poly motor mounts
and for oil I will be using the German Castrol 0w-30 and Delco filter
Yeah i asked him earlier
Old May 29, 2007 | 07:25 PM
  #170
WS6WRX's Avatar
Ah, the 4.11 gears explains why his #'s are so close to mine w/ the Hotcam. Definitely good #'s then.
Old May 29, 2007 | 11:26 PM
  #171
Thanks Kevin.
Well looks loke I'm halfway there. The 4.11's should be in later this week(12bolt) then I'll make my choice on which cam. I'm aimming for around the same Hp #, but my main concern is spring life. I dont want to change and check springs every now and then.
Old May 30, 2007 | 12:26 AM
  #172
JBIRD02's Avatar
ok..
378rwtq
Congrats on the new cam! Just curious, how do you like the 4.11's with this cam? I've been thinking of switching to 3.73's but my 3.42's already make 1st gear worthless with the ASA.
Anyways, again, congrats on the new found power!
Old May 30, 2007 | 05:15 AM
  #173
I have 4.10's in my 10 bolt with my ASA. And i will say there will never be any other gear than a 4.10 in my car. I LOVE IT
Old Sep 13, 2007 | 01:25 AM
  #174
Black Plague's Avatar
Ordered this cam for my 04' AWD Silverado SS cant wait to install and get it tuned look out tundras A guy ran really good numbers on a SS truck on pt.net drag section for the mods!
Old Sep 13, 2007 | 10:33 PM
  #175
Originally Posted by litle8
wow talk about bringing an oldie back to life LOL!
blackplague don't forget to compliment the cam,like long tubes,free flowing exhaust,chromoly pushrods,a better oil pump(I used a melling), good luck! if you click on my sig you can see my tuning videos!
salmanq, what specific info are you in need of?
Yes It already has full OBX stainless longtubes to a Borla dual cat back & GMPP intake. Am doing 2800 stall with shift kit as well hope to do low 13's
Old Sep 14, 2007 | 12:04 AM
  #176
litle88's Avatar
Black plague goodluck!!!
Old Sep 29, 2007 | 02:03 AM
  #177
diablo078's Avatar
im going to buy the asa cam and i was just wondering how the cam is with either nos or supercharger.
Old Sep 29, 2007 | 08:08 PM
  #178
I would think look for a different cam for a blower but spray away with it!
Old Oct 1, 2007 | 07:57 AM
  #179
SSsuperdave's Avatar
From what I've read the ASA cam won't be good for a supercharger because of the valve overlap that is ground in will cause you to loose cylinder pressure that is made by the compressor. All the extra pressure will go down the exhaust!
Old Oct 1, 2007 | 08:00 AM
  #180
Btw, is anyone running SLP 1.85's with this cam? I've got a set on order and just wondering if anybody has any input.
