Thoughts on ASA or GM HOT CAM
I will find out may 19 or 21st.. tuning will happen on the 18th..
so far, i have seen in the Dyno section.. most people are making 375-400rwhp with the usual bolt ons (long tubes, LS6 intake, Lid, ORY, catback, ect) i would be happy with 375rwhp.. and elated with 390+rwhp
are you an A4 or M6?
https://ls1tech.com/forums/generation-iii-internal-engine/689791-calling-all-cam-experts-can-someone-help-me-id-these-cams.html
thanks
do you happen to have a better picture of your dyno graph?
here are my mods
BBK 80mm TB (came on the car)
Granitelli lid, paper air filter
Granitelli MAF descreened (came on the car)
LS6 intake
241 heads milled .028 (calculated compression of 10.7.1)
GM ASA Cam 226/236 .525 .525
LS2 Timing chain
LS6 oil pump
03+ LS6 springs
GM MLS Head gaskets (.060 thickness)
Pacesetter Long tubes ceramic coated
Pacesetter ORY
Texas-Speed Rumbler catback (single 3" Dynomax Bullet in the Y)
other mods are:
SPEC 3+ clutch
New GM stock flywheel
updated hydrolics (with Drill mod)
Pro 5.0 shifter
rebuilt T56 from T56 rebuilds, 1B package
GM 4.11 gears
C5 front brake conversion
Eibach pro kit
Hotchkis APHB
BMR relocation brackets
Hotchkis trailing arms
Poly motor mounts
and for oil I will be using the German Castrol 0w-30 and Delco filter
idle was a bitch to get because of the crappy BBK tb on my car (i didnt buy it).. so we had to play with the set screw 1st.. then tune..
idles at 900rpm.. and this thing just pulls and pulls.. love the sound, love the power.
Let us hear it!!and see it!!
