382 small bore or big bore?
Old Dec 12, 2002 | 07:59 PM
FastBlackTA's Avatar
Default 382 small bore or big bore?
Ok, I've beat this issue into the ground but I want to make sure before I start an engine buildup and spend a ton of $$$. I was looking to build a 422 but the price might be out of my range so the next best choice is the 382.
Hate to sound ignorant, but I can't get a clear answer from anybody around: do I have to upgrade to a stage III head setup if I go with the small bore?!? I know head mods will be on order for the big bore....
Finally,
What kind of hp numbers are you guys with 382's putting down? I'm definately going to run a DP fogger in the future
for my goal of low low 10's. I've finally got the 12 bolt to handle the power, now it's time to build a real engine
Let me know what you guys think!
Thanks
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 12, 2002 | 09:20 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: 382 small bore or big bore?
Sent you mail <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
__________________
Old Dec 13, 2002 | 12:07 AM
Trevor D
-if you sent the e-mail to my aol address, please try and send it to caschenb@nd.edu since i don't have my aol account anymore....thanks for the help!
anybody else out there with any info please help out! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> need to get this project going!
conrad
Old Dec 13, 2002 | 07:24 AM
Ed Potter @ LPE's Avatar
Closed ex-Sponsor Account
on your small bore motor, anything bigger than a 2.050 - 2.060 intake valve won't really show you an improvement. I would recommend a stageII head, and maybe a little hand work in the runners to get the max flow out of them. Anybody's CNC heads will make decent numbers, and can be improved a little with hadditional handwork.
Have you seen recent posts concerning Darton re-sleeved blocks? I'm not sure what kind of budget you're on, but the re-sleeved block is about half the price of a C5R block.
Ed
Old Dec 13, 2002 | 08:54 PM
Black Sunshine/ 00SS's Avatar
I just ordered an All Bore 393 from ARE. Give them a call and ask for Wade. He will explain everything to you and answer all your questions.
You do not have to upgrade to a stage 3 head. The chamber will have to be enlarged to match the bore.
I'm still looking into what cam to get. I do plan to spray the hell out of it, after I get it dialed in NA. I'm getting the all bore now, because of the $$ issue, but also because now I can upgrade the pistons rod and crank later down the road, and get the 422 or 436. Give Wade a call. Good luck.
Old Dec 13, 2002 | 08:58 PM
Alonzo Version 1.0's Avatar
Yeah listen to ED he knows all about big ****** I mean bores.
<small>[ December 13, 2002, 08:58 PM: Message edited by: Alonzo Version 1.0 ]</small>
Old Dec 13, 2002 | 11:45 PM
Ok, I just got some info on the Lunati 382 stroker setup. The pistons included in the kit are 8cc dish...what kind of compression ratio would I get with my cartek stage II ls1 heads (The current comp ratio is about 10.8:1)?
Does anybody know if MTI, agostino, or cartek use the lunati kit for their strokers? I've heard good things but I was wondering if the "big name" reputable companies used them as well.
Thanks for all your help!
Conrad <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 14, 2002 | 12:04 AM
SLED28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FastBlackTA:
<strong> Does anybody know if MTI, agostino, or cartek use the lunati kit for their strokers? I've heard good things but I was wondering if the "big name" reputable companies used them as well.
Conrad <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Conrad, ARE has been using Lunati kits, but not off the shelf complete kits. We use ROSS pistons with Lunati rods and cranks, a custom kit with thick ringlands for heavy abuse. Lately we have been using Callies and Cola cranks...
Our All-Bore 385 motors seem to make 15-20rwhp more than our stroker 382's, I think its unshrounding the valves and letting the heads flow to their full potential...
Dave
www.agostino-racing.com
Old Dec 14, 2002 | 09:09 AM
Dave,
How much would you guys sell an all bore 382 balanced (pistons hung) rotating assembly and machined block? I've talked to some people and they think that this is the way I should go...
Thanks,
Conrad
Old Dec 14, 2002 | 09:17 AM
Ragtop 99's Avatar
Fast:
Check out ARE's website or post in the sponsors section. They have 10% off right now on motors so an assembled motor would probably be better then doing it yourself and just as cost effective.
Old Dec 14, 2002 | 09:18 AM
sorry i meant 385
Old Dec 16, 2002 | 02:30 PM
"Dave,
Thanks,
Conrad "
Price is about $5130, that is minus heads.
