Low oil pressure
Old Dec 15, 2002 | 09:46 PM
MR.MIX's Avatar
Default Low oil pressure
Got the new motor in,fired it up and what do you know?Oil pressure SUX.Pressure at idle is showing 0 at 4000 it shows 35. I've changed the o ring,the pump,the filter,and I've checked the o ring and the pick up tube seating 3 times now. WTF??? Does anyone have a clue? PLEASE HELP!!! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 15, 2002 | 10:01 PM
MR.MIX's Avatar
Default Re: Low oil pressure
TTT <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 15, 2002 | 10:30 PM
xssive's Avatar
Is this a new motor or did it have work done at a machine shop? If it was machined, check for the plug on the back of the block. If its not there, you will have little to no pressure. Do a search on here and you will find more info on it
Old Dec 16, 2002 | 10:34 PM
MR.MIX's Avatar
Thanks alot...That is exactly what it was.Finally up and running. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 17, 2002 | 03:53 AM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MR.MIX:
<strong>Thanks alot...That is exactly what it was.Finally up and running. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Holy ****. I hope you weren't running around too long without the plugs. Next time, if it's 0psi at idle, I'd stay away from reving up to 4000rpms.
