Who upgraded from B1 to something bigger on S2 heads
My buddy's looking for a bigger cam for his MTI S2 H/C/I car. Anbody have a significant gain by going w/ an XE-R cam or a big TR cam? He told me a while back that Jayson said that you wouldnt gain much by going bigger than a 224*. He was looking at an XE-R ~224 or a reverse split TR cam. Thx.
Brad, I have a 232/236 112 ls, on a XE-R grind that I will be selling this winter. I got a different motor coming. Give me a yell if you tink he might be interested. It wasn't in long. He can even hear it run if he wants. It is still in the car.
Sunshine---- How do you take off with you set-up. When I do N/A I smoke the tires pretty good, When I spray I really break them loose. I plan on goint to the track in Jan and want to get good times. I have 315/35/17 Nitto`s on back with 17x11`s. I`ve got the same stall as you with 3.73 gear and 12-bolt. Let me Know!
Restricted User
You need a set of ET Streets. I would over power a set of Nitto's with a stock motor and a converter. Either you buy a set of Streets or part throttle it off the line...
