LS6 Heads Chamber size?
What would 60.5 bump the CR to with a stock bottom end and GM head gaskets?
Need some info right away, thanks <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ December 16, 2002, 05:40 PM: Message edited by: I8COBRA ]</small>
I got these heads already ported but never run. The guy said they werent milled. Had them flowed this weekend and also had the chambers checked and they measured 60.5
I'm still gonna get them resurfaced minimally so I'll be at around 11.0, thats exactly where I wanted to be at <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<strong>I would feed the motor more cam. Especially with the higher compression and the better breathing LS6 exhaust. Should be closer to a 224/228 .580 lift on a 113 LCA.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I dont want to go with that much lift, worried that I'll start slapping my pistons. Plus I want this car to be VERY streetable since I only make it to the track 3-4 times a year.
<strong>My 02's measured 64 cc with 01 valves.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey Don -- which head gaskets are you using for your 02s? GM lists 98-01 and 02-04...can't seem to find a difference, furthermore I thought 01 and 02 heads were cast the same, just with a diff valvetrain.
Thanks,
-N
