ls1 head gaskets $17 each!!!!!!
Old Dec 20, 2002 | 07:14 AM
00bluehawk#111's Avatar
Default ls1 head gaskets $17 each!!!!!!
just to let other members know. detroit gasket makes head gaskets for the ls1 and i just ordered a set from my machine shop. they were $17 each and the head bolt kit was $17 per side hope this helps some folks out. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 20, 2002 | 08:45 AM
parts@sdpc's Avatar
Sponsor
Default Re: ls1 head gaskets $17 each!!!!!!
That is a great price. We also have the GM gasket for only $24.15 for the pair. GM Performance Parts LS1/LS6 Head Gaskets
Old Dec 20, 2002 | 05:46 PM
thats an awsome price!! how come some folks try to kill you on price?? how much are the head bolt kits??thanks for the info!! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Dec 20, 2002 | 10:48 PM
2001 Pewter WS6's Avatar
Restricted User
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> That is a great price. We also have the GM gasket for only $24.15 for the pair. GM Performance Parts LS1/LS6 Head Gaskets </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">On your site the 1997-2001 are one type of gasket and the 2002 is different. Other vendors show 1997-2000 are the same and 2001-2002 are the same. Please advise.
Old Dec 21, 2002 | 08:55 AM
O6blues's Avatar
SDPC posted some technical info about this before. Check this out---
https://ls1tech.com/ubb/ultimatebb.p...=006529#000000
This should answer your questions on head gasket applications.
Old Dec 21, 2002 | 11:28 AM
Restricted User
I read that the 99-01 are the same gasket. The head casting numbers are #241 but wasn't the blocks changed mid year to the LS6 block? Wouldn't this make a difference? If the heads are identicle from '99-'03 then the difference has to be the block. If the heads changed in '02 then it would be a different casting number. So if I have #241 heads and LS6 block, wouldn't I need the newer style head gaskets???
Old Dec 23, 2002 | 11:34 AM
Restricted User
??? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> ??? Anyone???
Old Dec 23, 2002 | 11:40 AM
Ed Potter @ LPE's Avatar
Closed ex-Sponsor Account
as far as head gaskets are concerned, the block makes no difference. You need to look at your heads, if they have the notch in the deck, then you need the earlier gasket, if not, then you need the later gasket.
Ed
Old Dec 23, 2002 | 02:29 PM
AZLS1's Avatar
GReat Prices SDPC! I just placed my order!
Sterling.
Old Dec 24, 2002 | 07:19 AM
Restricted User
Thanks Ed.
