Valve to piston clearance on MMS 224 and other notes…
Old Dec 22, 2002 | 07:00 PM
C_Williams's Avatar
Default Valve to piston clearance on MMS 224 and other notes…
The cam is from Comp Cams, no surprise, and here are the specs:
Grind # LS1 3314R / 3314R HR 114+4
IO 2 BTDC
IC 42 ATDC
EO 50 BBDC
EC 6 ATDC
Installed on 110 Intake C/L
Duration @.050: 224 I / 224 E
Lobe Lift: .335 I / .335 E
Lobe separation: 114 LSA
Piston to valve clearances
Intake vale clearance: .084
Exhaust valve clearance: .111
Note: LS6 heads by CNC / 62 cc (milled .020)
Old Dec 22, 2002 | 10:09 PM
99 Black Bird T/A's Avatar
Default Re: Valve to piston clearance on MMS 224 and other notes…
Sounds right to me.
My 5.3 heads were milled at least .015 to .020
My 224 XE-R has .075 P to V on intake
I've seen my 224 XE-R spec's overlayed with the MMS224 spec's from a cam doctor, the XE-R was a hair more aggressive.
Old Dec 23, 2002 | 12:18 AM
timbalan77's Avatar
Can anyone recommend a website with a detailed write-up that explains in detail what all the different #s mean regarding cams (lift, duration, etc)? I'm a bit ignorant in that area. Thanks.
Old Dec 23, 2002 | 12:33 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by timbalan77:
<strong>Can anyone recommend a website with a detailed write-up that explains in detail what all the different #s mean regarding cams (lift, duration, etc)? I'm a bit ignorant in that area. Thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Check out Comp Cams website
