MTI C1 CAM VS MTI C2?
Which would be better for an Automatic car with Ported Cylinder Heads?
Car is driven on street, but is only race in the 1/4 mile.
Thanks In advance
There's not much difference.
C1 will tend to make a little less hp, but be easier on the valve train.
C2 will tend to make more power because it has more lift and duration and be harder on the valve train.
My SRP224 is very similar to the C2 and drives fine with MTI tuning. Ported heads are always good. Get dual springs and you'll have less issues out of either cam.
<small>[ December 23, 2002, 02:36 PM: Message edited by: 99 Black Bird T/A ]</small>
<strong>
Get dual springs and you'll have less issues out of either cam.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Should I get dual springs with stock heads? Or would 918's do alright?
<strong>Don't know about the C2 but you do not have to fly cut for the C1.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">MY SRP224 is very similar to a C2, a 224/224 XE-R. My car had the tighest P to V clearance of any car I know of with a 224 sized cam. My P to V was fine with the cam degreeded. Had .075 P to V. It's always best to check, but if my car was ok I think your car would be with stock heads as my had ported heads. If your getting ported heads talk with the porter but seldom (if ever) does any see serious P to V issues with a 224 sized cam unless the heads are milled a LOT.
