shaft mount rockers for HYD motor?
Old Apr 15, 2007 | 11:04 PM
skipperbisket's Avatar
Default shaft mount rockers for HYD motor?
I have a set of T&D Shaft Mount solid roller rockers that are from a previous setup. Are the shaft mounts compatible with hydraulic roller cams/lifters/springs?
Old Apr 16, 2007 | 01:43 AM
heavymetals's Avatar
Should be no problem, but don't expect to be able to use the same pushrod length.
