Cam Position High AND Low Codes
Old Apr 16, 2007 | 12:00 AM
Onyx LS1's Avatar
Default Cam Position High AND Low Codes
So after the 427 went out one too many times and the builder wouldn't back their work I stuck a stock rebuilt LS1 in my car. After we got everything buttoned up the car doesn't start well, the tach doesn't work, and it is throwing camshaft position codes. It is throwing cam position high and low codes (P0342 & P0343).
I am hoping the cam was torqued down and loc-tited good, and that it didn't walk in the block.
We noticed that the 98 Camshaft Position Sensor is a different part number than the other years, could my PCM be expecting signal from a 00 sensor and getting a signal with different amplitude or something from a 98 sensor?
Or maybe it is just a bad sensor?
Any help is appreciated!!
Thanks, Justin
Old Apr 16, 2007 | 12:11 AM
Onyx LS1's Avatar
Also, I reset the codes one time and they came back on immediately. The second time it took ~15 miles before the SES light came back.
Old Apr 16, 2007 | 10:09 AM
Onyx LS1's Avatar
nobody?
i guess i'll start with swapping the sensor
Old Apr 16, 2007 | 01:57 PM
cowboysfan's Avatar
if it was tuned for 427 and you got a lS1 in there now, well yea! that could be problem. tune it for LS1 man!!!!!!!!!!!
Old Apr 16, 2007 | 05:35 PM
Onyx LS1's Avatar
lol it has a stock program back in it
Old May 12, 2007 | 10:17 AM
slmdLS1's Avatar
did swapping the sensor fix it?
