Anyone Know the Weight Difference Between 6.0 Iron block and Ls1?
Old Apr 16, 2007 | 09:42 AM
1999ssls1's Avatar
Default Anyone Know the Weight Difference Between 6.0 Iron block and Ls1?
I am wanting to know because I had lowering springs on my car with the ls1 and then I put the 6.0 in and it was sitting on the tires. Then I put factory springs back on and its still too low. My car scrapes on the road itself sometimes.
Old Apr 16, 2007 | 09:45 AM
Black02Bird's Avatar
according to a book at autozone at least 88 lbs, but that was for a 5.7, so figure around 100 or so lbs
Old Apr 16, 2007 | 10:03 AM
1999ssls1's Avatar
Its about time to lighten it up then.
Old Apr 16, 2007 | 02:54 PM
86RedRocket's Avatar
65 lbs. was what I read.
Old Apr 16, 2007 | 02:59 PM
Whistler's Avatar
Sawzall and Welder Mod
It's closer to 100
Old Apr 16, 2007 | 04:11 PM
Yousif Q8's Avatar
100 lb
Old Apr 16, 2007 | 04:17 PM
2000 Ultra Z's Avatar
just weight them 81lbs different
Old Apr 18, 2007 | 10:30 AM
CamaroRick's Avatar
my 6.0 iron weighed in around 250Lbs
Old Apr 18, 2007 | 12:51 PM
Juiced's Avatar
i sure hope that was with crank and rods, or you might be needing a new scale.
Old Apr 18, 2007 | 02:11 PM
JunkyardZ's Avatar
always heard around 100 lbs.
Old Apr 18, 2007 | 02:30 PM
slmdLS1's Avatar
i was told 60-70 lbs.
Old Apr 18, 2007 | 02:40 PM
TeEnAgE pHeNoM's Avatar
So if it is that heavy does it mean that you are offsetting the power you gain by the weight?
Old Apr 18, 2007 | 02:47 PM
slmdLS1's Avatar
fyi, here's my car with the same DMS springs after my 6.0 block...
Old Apr 18, 2007 | 04:50 PM
xturboguyx2001's Avatar
i wouldnt worry so much 65-100 pounds is worth it if you plan on getting the thing over 700hp. (with good internals)if not. i would stroke the alum. block.(with goodinternals) dont resleeve its not worth the problems!
Old Apr 18, 2007 | 05:01 PM
the_merv's Avatar
Actually he is right, I have a 6.0 block in my Kitchen. The LT1 weighs about 225lbs, that 6.0 is a little heavier, about 250lbs. I can barely lift it up, and I can throw a LT1 around fairly easy.
A way to fix your Suspension, look for a set of LT1 front Springs. I am dropping that 6.0l in a LT1 Car, I have an Eibach kit in it, so I am already setup.
Old Apr 18, 2007 | 05:45 PM
1999ssls1's Avatar
got the pm, thanks the_merv
Old Apr 18, 2007 | 06:21 PM
the_merv's Avatar
No prob. You should be good after all that is done..
Got to love them Iron Blocks.
