Spark plug tricks?
Use 20" long 3/8 extension and universal on the rear drivers side.
Remove#8 from underneth car.
works like a charm no extensions or nuttin. p.s. sportin some dynomax LT's here.
no air pump or EGR in the way with pacesetter lt! All i have is 3 bolts holding on each coil pack "Fu** the back bolts" I use a spark pug socket with a 3/8's swivel taped to it with electric tap to hold them together and also around the swivel part to stiffen it up and use it with a ratchet and that's about it! Ii makes it so easy!
