Just enough head? Lol!!!
Old Apr 17, 2007 | 08:57 AM
Jrp1978's Avatar
Default Just enough head? Lol!!!
I have a 2002 camaro with tr 224 cam and full bolt ons . It made 376hp and 366trq I would like to hit 400 what heads can i get that will get me atleast to 400 hp?
Old Apr 17, 2007 | 10:06 AM
PREDATOR-Z's Avatar
TEA 243s stage 1.5
Livernois 243 220cc stage 2
PRC 243 stage 2 (2.02 valves)
PP 243s stage 2 (2.02 valves)
AFR 205s
Edelbrock 200
TFS 215s
Old Apr 17, 2007 | 10:07 AM
brad8266's Avatar
Old Apr 17, 2007 | 10:50 AM
Jrp1978's Avatar
Default ok
So witch ones are the best deal!
Old Apr 17, 2007 | 10:56 AM
BIG_MIKE2005's Avatar
A good set of 5.3 heads worked over should get you there too along with some higher compression.
As for best bang for the buck I'd go with these:
http://www.texas-speed.com/shop/item...d=649&catid=40
Old Apr 17, 2007 | 11:06 AM
98Z28MASS's Avatar
Patriot perfromance, livernois, and prc 243 castings are probably the best bang for the buck. You might make a little more hp with the other heads but they will cost you.
Old Apr 17, 2007 | 11:11 AM
98Z28MASS's Avatar
also as big mike suggested you could look into some patriot 5.3's or prc 5.3's to up your compression a little as another option.
Old Apr 17, 2007 | 12:23 PM
LivernoisMotorsports's Avatar
If you're looking for a great head at a great price, we've made more power than you are aiming for with our stage 1 and stage 2 heads with cams similar to yours. My C5 made 420 RWHP / 390 RWTQ with our stage 1 cnc head, 224/228 114 cam, Longtubes, X-pipe, Stock Z06 catback, and LS6 manifold.
These heads can be found at the following links:
Stage 1 CNC LS6 Heads
Stage 2 CNC LS6 Heads
Thank you
Regards,
Rick LeBlanc
Livernois Motorsports
