Poll time- which cam would YOU choose?
If you want great drivability this is one of the best cam choices. Its been power & E.T. proven time & time again.
Im thinking the 228/232 110+2 DOT TO FREAKIN DOT.....how's that sound fellas?
BTW, blew up my 10 bolt yesterday on an 1/8th mile track
I would probably still go a tad lower on the cam specs for what you want.
Thoughts?
As far as the cam goes, you think I shoudl go smaller huh? How bout a good ole fashioned 224/224 on a 112 with a healthy shot??
Erik
What are your plans for the shortblock you are wanting to build? FI or NA.
I would like to see you use something in the 224-228 range. It will bring your peak numbers down for drivability. I like my cam but I actually wish I would of gone with something smaller. Numbers don't mean anything- it all comes from the numbers under the curve, but I know you already know that.
All cams will work great with spray as long as you are keeping the shot under 300.
Hey Mike,
Well, to be honest, I am looking for a rear now lol jus dont knwo if I can find the funds for it, what can you do for me?
I need the 9" that works with 4 channel as I am keeping TCS and all...you sure true trac will be strong enough, even when a forged motor goes in there one day?
(Oh yeah, I aquired an '01 ls1 from a bud-had a spun bearing- for like $100...couldn't pass it up! I plan on cleaning the block up, forging the rot. assembly, and probably build it for a heafty shot of n20....I just dont see the funds for FI coming anytime soon...I believe my FI days will be further down the road...)
As far as the cam goes...well I dont know...the whole purpose of this swap is because I am unhappy that I didnt break 400 ft lbs of torque...WTF! Is it true that even though my peak power will drop say 20-30 HP, my TRQ will inrease to over 400 and driveability will greatly improve?!?! If not then I feel that I am wating my time here and I shoudl just keep what I have, continue to have the tune tweaked and throw say a 50 shot on there for fun.....
Let me know man...thanks!
Even if you change cams out you will probably go down in TQ. but not by much. You made some decent TQ. so don't worry about 400 as you are very close. Its not all peak remember that.
Also what gears did you have in the rear, as a set of 4.10 or 3.73's would work well. If you were on the stocker 3.42 that could be adding to hating the tune for the moment, as you would get soem surging at lower rpm's.
