Pictures of the damage
Old Apr 27, 2007 | 12:12 PM
02Z28's Avatar
Default Pictures of the damage
Well I lost compression in the number 7 cylinder after my first trip to the track with the new set-up. Didn't even use the nitrous, I guess it was a good thing I didn't. What would have caused this? The last time I used the nitrous was on the dyno, and it ran fine after that.
Old Apr 27, 2007 | 12:25 PM
TheCarKid's Avatar
same exact thing happened to me but on cyl. 5. found it during a cylinder leakdown test had about 80% leakage. I bought the car used but I never sprayed on it. Just got some forged pistons and called it a day. I really couldn't tell ya how it happened but the guy at the machine shop said he's only seen that happen to nitrous cars. made me wonder if my car was sprayed before i bought it.
Old Apr 27, 2007 | 12:28 PM
delsold's Avatar
what mods were done to your car? it looks like the ringlands blew out which is usually caused by over cylinder compression or heat. Maybe you weakened them on the dyno with the spray, and then it just let go at the track
Old Apr 27, 2007 | 12:38 PM
02Z28's Avatar
Thats what I think happened. My mod are in my sig. I sprayed a 150 shot on the dyno.
Old Apr 28, 2007 | 08:53 AM
HaulinHawk's Avatar
Damn thats sucks man!!!Build it up bigger,stronger,faster.What kind of #s did it put down ?
Old Apr 28, 2007 | 08:35 PM
Robert56's Avatar
here's what mine did after a 285rwhp shot with to much cly heat (665rwtq at 3800rpm on stock longblock).
Robert
Old Apr 28, 2007 | 08:47 PM
02Z28's Avatar
Think it was a little over 560 on a 150 shot.
Old Apr 28, 2007 | 08:49 PM
02Z28's Avatar
Robert
Ouch! LOL can't expect to much out of the stock bottom end!
Old Apr 28, 2007 | 11:09 PM
Formulated's Avatar
It looks to me like heat damage. I wouldn't be surprised if your top ring groove is beat out, and the top ring quit sealing. Fuel probably got into the land between the two compression rings, and burned itself away. The best fix for this is to retard the ignition timing. Since you're rebuilding the engine now, look for an improved ring pack.
