Question on built motor
Old Apr 30, 2007 | 07:14 PM
Black C5 Z06's Avatar
Default Question on built motor
Would it be possible to run an 11.5:1 CR motor on 93 octane pump gas?
Here are the specs on the short block I'm looking into
It's going to be a street car, but I want a N/A car so this is perfect, IF I can run pump gas in it.
Thanks
New LS6 block
Scat rods
Diamond "11.5-1" pistons with valve Relieves
stock crank
balanced and "blue printed"
He is asking $3200 for it
Old Apr 30, 2007 | 07:57 PM
orangeapeel's Avatar
ЯєŧąяĐ Єlˇmˇиąŧřя ™
Moving to internal.
Old May 1, 2007 | 07:23 AM
slow trap's Avatar
is it a dome piston or something ? only way to get that high of a compression is with heads milled down to around 60cc or so,give or take a few cc depending on head gasket thickness.i ran 11:6- 11:7scr with 8:9-9:0 dcr just fine on 93 octane so you shouldn't have a problem with a good tune imo .if it is a flat top motor with maybe -2 or -4 cc pistons you will have less compression than stock unless you mill your heads/use thinner gaskets.
Old May 1, 2007 | 08:03 AM
PREDATOR-Z's Avatar
Watch out for DCR.
Old May 1, 2007 | 08:34 AM
Originally Posted by orangeapeel
Moving to internal.
Yeah, sorry, I realized I put it in the wrong section like 10 minutes after I posted up
What's DCR?
Old May 1, 2007 | 11:01 AM
PREDATOR-Z's Avatar
It is not Static Compression Ratio (SCR) which determines if a cam will handle the octane, but the Dynamic Compression Ratio (DCR)
For an explanation just search in the web, you'll find lots of articles.
Old May 1, 2007 | 01:16 PM
So, would the DCR be changed according to what cam I put in?
That's what it sounds like according to the article I read.
I'm probably wrong, so that's nothing new
Old May 1, 2007 | 02:04 PM
slow trap's Avatar
yes it will change.the bigger you go the less dcr you will have. something like a 232/234 xer lobe on say a 112 lsa+2 would work great with a pretty high dcr with 11:5 scr but something like a 236/240 on a 114 lsa or so would have quite a bit less dcr.
Old May 1, 2007 | 04:35 PM
Well would high compression like that be good for a high revving motor?
And how could I build a motor that can rev and rev and rev.
I don't want a ton of down low torque.
Yeah, you guessed it, I want a motor for road racing.
Now how could I build a motor like that? High compression?
Thanks for the help
