BAD internal noise after start up. Expert help needed!
Old May 4, 2007 | 04:10 PM
V8er's Avatar
Originally Posted by AintQik
Yeah all hell broke loose in my motor. Dug up the cam, then jammed the lobe up and broke the gear off the camshaft causing the piston to slap a few valves.
I am quite sure this is an ignition or electronic problem, not broken internals.
Old May 4, 2007 | 05:49 PM
Viper's Avatar
If you have HPTuners etc you can at least see if it's misfiring in what cylinder to narrow your search down. But I would immediately pull the valve covers and look before asking anything else to at least eliminate that.
