What is the flow rate of the LS1 oil system?
I want to make sure that the flow rate of the oil system isn't a LOT more than 5.5 GPM. Does anyone have a figure for this one? If it matters, I'm talking about the flow of oil that exits and enters the ports on the driver's side of the block just above the oil filter.
Thanks,
-ch
There's got to be a GM engineer around here who knows for sure.
http://www.mcmaster.com/nav/framewor...=7775K54&t1=PN
Assuming that the specific gravity of oil is about 0.9, these valves will have 1 psi drop at 6 GPM which seems reasonable.
I just want to make sure I'm not choking off my oil system with this part.
-ch
