CRAP!!! Boke a oil pan bolt!!!
Old May 5, 2007 | 11:29 PM
KurtRardin's Avatar
Veteran: Marine Corps
Default CRAP!!! Boke a oil pan bolt!!!
CRAP!!! I feel so stupid. My torque wrench didnt click Its the back right EXTRA LONG bolt, as in starter side. Its easy to get to, but its got maybe half or more of the threads to it broken off up in there.
Heres a question that I am already feel stupid for asking... Do you think it would be okay without it...its got the horizontal bolt right under it that is still good. ?
I dont know how I would even begin to get that thing out. I would probably need to remove the pan, huh?
HELP!
Old May 5, 2007 | 11:47 PM
KurtRardin's Avatar
Bump cuz this is urgent!
Old May 6, 2007 | 05:09 AM
DaddySS's Avatar
Not too many choices here - oil pan off and take the time to fix it or leave it and see how bad it leaks.
Otherwise you'll need a sleeve to center the drill bit, a long drill bit, and a long extractor. By the time you find/make those things it probably would be easier to remove the pan.
Old May 6, 2007 | 06:21 AM
KurtRardin's Avatar
Thanks. I'm gonna try doing nothing at all first and see how long that takes me. I have a feeling that as soon as it heats up it will leak... but we'll see. Anyone else?
Old May 6, 2007 | 10:19 AM
KurtRardin's Avatar
Anyone else have any ideas?...experiences?
Old May 6, 2007 | 10:20 AM
98TADRIVER's Avatar
dohhhhhhhhh i did that to a cam one time, i had it set to the wrong line, 5ftlbs more! it killed me
Old May 6, 2007 | 10:21 AM
KurtRardin's Avatar
I've got my springs left to do, then button everything back up, tune it with my Vinci, then start it up. I'll let everyone know how it does. I'm sure that with the new oil pressure its gonna leak.
Old May 6, 2007 | 10:50 AM
ATXCAMAROGUY's Avatar
Just see how bad it leaks, if it's bad your gonna have to pull the pan. Now you know you don't have to torque those bolts, they just need to be hand snug in there.
Old May 6, 2007 | 11:33 AM
KurtRardin's Avatar
Yeah, I figured that out now. I will probably need to drop it anyway to put a new gasket or RTV on it later. Are we talkin just drop the pan like before (to drill this thing out) or actually remove the pan...like pull the engine loose and jack it up?
Old May 6, 2007 | 12:54 PM
85ta383's Avatar
if you drop the pan the 1/2 inch it lets you you might be able to get a set of vice grips on the nub sticking out.. that wouldnt be that big of a deal to do unless it broke off flush with the block?
Old May 6, 2007 | 12:57 PM
Lurius's Avatar
Are you talking about the loooooong ones(m6?) that go up into the rear cover? Thats going to be hard to fix.. If you can get the remainder of threads in it, you may consider just putting it in with some locktite? Make sure you ahve torque specs correct. Soemone said above "ft lbs" I think that bolt is actually torqued in inch lbs.. 106 sounds right in my head.
-Lurius
Old May 6, 2007 | 06:10 PM
KurtRardin's Avatar
they were 10mm, but yeah, they were the loooong ones. on the back of the oil pan. Not the horizontal bolts, but the ones that are at the corner. Half or 2/3s of the threads are still up there. No nub. I am hoping that since its on the high side of the oil pan that it wont leak...or leak much. There will be a 6.0 there in a year. If its a quart a month then I'll keep addin baby. Lets just hope it isnt a quart a minute!
Im puttin it all back together now and getting ready to fire it up (first cam install). I'll be back in a few hours...
Old May 6, 2007 | 06:57 PM
02Z28's Avatar
I just fixed mine a month ago! Dropped the pan down and moved it over, and there was enough bolt sticking out that I got some vise grips on it. I guess I got pretty lucky.
Old May 6, 2007 | 08:46 PM
KurtRardin's Avatar
Did yours leak everywhere?
Im baking my balancer as we speak, so I'm getting there!
Old May 6, 2007 | 09:57 PM
KurtRardin's Avatar
Wow... car still isnt together. My longer bolt didnt have a big enough face on it to grab the balancer... So, after I scowered the garage to find anything that would work I decided to just hang it up until the hardware opens.
Old May 6, 2007 | 11:14 PM
hallsj1's Avatar
Did the same exact thing, still driving. Just a little seepage, which is to say the oil pan is a little wet. Other than that life is good; gonna leave it. Basically I'm too lazy to fix it.
Old May 7, 2007 | 08:47 AM
KurtRardin's Avatar
Did you rtv the heck out of the pan gasket before? I was thinking about maybe putting some RTV around the outside of it. That stuff dries and is like rubber! Did you break the same exact bolt?
Old May 8, 2007 | 08:51 PM
KurtRardin's Avatar
Okay.......... No leaks ....... no drops..... NOTHING!!!!!!! I am going to keep an eye on it from now on, but man, almost 200 miles later and no leaks. Awesome
Old May 10, 2007 | 05:13 PM
2 SSlow's Avatar
i did that too..just said F-it. Left it broken for the last 30k+ miles. It never leaked, but that back corner seeped more than the rest of the spots on the pan. A lot built up on the starter.
Old May 10, 2007 | 05:15 PM
half-n-half's Avatar
i did the same, and also said f it no leaks here either, havent looked for seepage though
