Anyone here good with Jeeps?
I'm getting really pissed off at mine. 6 months ago I had an intermittent low RPM (1500-2000) stumble. Did plugs, wires, cap, rotor and the problem was solved, the old distributor cap was kinda nasty and worn underneath, so it ran like a champ with a new one on there. The other day it started acting stupid again, and since I had a warranty on the wires I changed them again, and switched my spark plugs to a different kind. Nothing. Tonight I pulled the cap and rotor off, and they both had some corrosion so I ran to Murrays (gotta love 24 hour parts stores) and replaced them both. Still missing. Any ideas? When I pulled the plugs they still looked pretty new, too new almost. They should be golden brownish but these were still pretty white. What would you guys check next? It's a 99 with a 4.0, about 112K on it which for a 4.0 is nothing. I have noticed if I pop it in neutral it revs fine, but when I am in gear it accelerates goofy and jumps until I get above 2 grand, then it is fine. Then since I cruise about 1700-1800 @ 45 mph, it bucks and acts stupid there sometimes too.
I didn't see any vacuum leaks, and I am dreading the fuel filter as I have to drop the tank to replace it. Chrysler did some really stupid things when they redid the cherokee in the late 90's.
makes a whisteling sound untill you push on the gas petal.
