**Split the block, broke a piston, what a night, hardcore engine people inside***
Um, I was running 22/23 psi boost. i believe I injested the fuel pump sock, causing it to go lean. It was more than a few bad sounds. One connecting rod is still missing and another was turned into splinters in the oil pan.
Along with everything else, broken tranny case.
That was crazy.
Well, they allways say; You know you have finally exceeded the motors limits when you drive over your crankshaft! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Ron,
ex-owner 89 TTA 11.87 @ 114
