**Split the block, broke a piston, what a night, hardcore engine people inside***
I was out racing and sprayed the car(900PSI like always) 2nd, 3rd, and 4th gear, and all of the sudden coolant light came on. I figured I picked up a head and blown a head gasket (I've had previous experience of this on my old blown mustang) so I towed the vehicle home since it was running really rough, which also had a small knock to it.
Upon inspection there was water in the coolant looked like chocolate milk so I assumed I blew the head gaskets no biggie. I take the valve covers, pushrods, rockers, exhaust manifolds and finally the heads off only to see a busted piston on the passenger side 3rd piston back, which explains the knocking, but I was looking at the heads gaskets and neither of them were blown ANYWHERE, which is very odd and doesn't explain my coolant problem.
I finally turned the motor over with a wratched to see if the cylinder walls were scratched only to find out that there is a huge 5"+ crack down the cylinder wall of my block! None of the other pistons/cylinders are hurt and there were no appart signs of detonation, etc on them either. This would explain where the coolant was getting in the engine b/c coolant was coming through the crack.
Now I've ran over 15+ bottles through this motor fine and have made over 75 passes on the car no problems at all.
The question I have is what happened and in what order. Did the block split first under high cylinder pressure(Nitrous), pumping coolant into the cylinder under the spray braking the piston or did it detonate brake the piston and then split the block?
I took the valves out of the head and they are perfectly fine and true. The head is not knicked anywhere.
Let me know what your ideas are.
Thanks. And if you got a used short block FS let me know <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
More than likely, you went lean, detonated, and blew the piston/cylinder at the same time. Then the coolant came in. Our pistons are pretty crappy, they are very brittle around the ringlands.
-Tony
The crack was probably caused by spraying over time, which finally allowed coolant into the cylinder, and hydraulicd the cylinder. The way the chunk of cylinder wall is pushed outward, toward the coolant passage should verify this.
We have shortblocks available, or we can do a Darton sleeved conversion for you, just give me a call if you're interested.
Ed
Thanks.
Here's my Turbo Buick v6, well, what was left anyway. <img src="http://home.earthlink.net/~sligtone/images/IM000080.JPG" alt=" - " />
<img src="http://home.earthlink.net/~sligtone/images/231Engine2.jpg" alt=" - " />
That doesn't look good... <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" />
<strong> Whenyou look under the car and see a cam lobe sticking out of the side of the oil pan, then you have killed a motor, yours looks like a mere flesh wound to me
Here's my Turbo Buick v6, well, what was left anyway. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That has got to be one of the worst engine blow-ups I have seen. The came lobe caught against the flex plate and sticking out of the oil pan is freaky. It must have made a hell of a bang. How much boost were you running? 30 lbs?
